System-Wide Fix for Gaming Mouse Fluidity in Windows 8.1
You have upgraded to Windows 8.1 from Windows 8, and noticed bad performance from your gaming mouse? More input lag and worse fluidity, even when dragging windows around on the desktop, not just in video games?
You’re not alone.
There is now a system-wide solution. Follow KB 2908279 Instructions, install the hotfix (skip that step if already installed), and then add c:\windows\explorer.exe to your registry in Step #4. Although Explorer is not a game executable, this solution enables the high report rate (e.g. 1000Hz) system-wide from your gaming mouse in all your applications. This fixes all fluidity including window dragging, scrollbar dragging, etc.
UPDATE: Microsoft has modified the page.
You may have the Microsft update already installed. A better step by step:
www.howtogeek.com/175722/how-to-fix-mouse-lag-in-pc-games-on-windows-8.1/
Instead of C:\Program Files (x86)\Game\Engine.exe, enter C:\Windows\Explorer.exe
With this fix, your mouse will perform as well as it did under Windows 7 and Windows 8.
NOTE: If anyone from Microsoft is reading this, see Comments for scientific explanations why 1000Hz is better for window-dragging/scrolling, even on a 60Hz or 120Hz monitor.
Also, see the new Blur Busters Mouse Guide.
About Mark Rejhon
Also known as Chief Blur Buster. Founder of Blur Busters. Inventor of TestUFO. Read more about him on the About Mark page.
21 Comments For “System-Wide Fix for Gaming Mouse Fluidity in Windows 8.1”
ikjadoon
Member
ikjadoon
Oh, sheesh, I didn’t notice it until you told me, haha. But, then, it was REALLY noticeable.
Thank you for the awesome fix. One restart and I was on my way!
sleetish
Member
sleetish
Just wanted to note a correction, it’s KB 2908279 instead of 290879
Thanks for all your work on this and other things to help everyone get the best experience possible.
wpDiscuz
Recent Content
